Hi Guys,
I use the oxygen 8 with reason the most of the time , but I was wondering if I connect it to my Dj console and use it as an effect box. Well I tried ! no chance ! it didn't work ! but I would like to know if some of u have the solution ! If not it's ok ! I think it has to do with the cable ! I have no clue how these things work !
Thks
Thks
Posted Mon 23 Jan 06 @ 4:26 am
@DJAngels
You can use the Oxygen8 as a midi controller not only to controll the effects but also the samples. Just connect the Oxygen8 to your PC. Go to the config panel in the VDJ settings. under remote controller put a check mark under "midi controller"
Now once this is done you need to go to your keyboard shortcuts tab and either edit or create new shortcuts but this time hit the key, knob or slider of the Oxygen8 and you'll be able to use the keyboard as you'd like.
I use the Ozone workstation with VDJ and it works like a charm.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
Posted Mon 23 Jan 06 @ 12:30 pm
Hey thks a lot man ! :) thank you very much !!!!!!!!!!!
Posted Mon 23 Jan 06 @ 8:27 pm
