Hi
I have searched this site for a while now and I am stil confused. I apologise if it is a stupid question but here goes.
How can I seperate the audio output so that I can listen to one track via headphones and cue it ready while the other is playing? Will it work if I buy an external soundcard and set one side to play through the external soundcard and one side to play through the internal soundcard? if so will any external sound card work as I dont want to spend much money.
Thanks
Chris
Thanks
Chris
Posted Mon 28 Nov 05 @ 11:09 pm
You could use and internal or external soundcard. or use both or use more than 2. You can listen in your headphones and send the master out with only one 4.1 (or better) soundcard.
You need the FULL purchased version of VDJ to get it working.
Posted Tue 29 Nov 05 @ 1:25 am
Sounds Good, Thanks
Posted Wed 30 Nov 05 @ 10:31 am
