Iam trying to record a mix for burning, Ive looked at the cue file and its seems wrong there are a couple of tracks are repeated and some tracks are missing - it seems to miss the 1, 3, 5, etc ie odd tracks and duplicates the 2, 4, 6 etc even tracks. Also the times for the index are wrong
Also does version three allow listening of the main program and cued track in the headphone together?
It would be great if we could record the mix as one long mp3 with cue file to split it up, winamp supports this and it would make it easier to listen back to before deciding to burn it. Other things virtual DJ could do with doing is give a total time for playlisted files so one can estimate whether they would all fit on a cd.
Thanks
Thanks
Posted Sun 28 Aug 05 @ 8:21 pm
Forgot to say im using the Herc DJ console version
Posted Sun 28 Aug 05 @ 8:24 pm
