I'd like to use the TC bypass feature with 2 Technics TTs and an ASIO Maya 44 USB soundcard, however, even though the TCVs work within VDJ, the TC bypass doesn't give me any sound at all when using regular vinyls (looking at the LEDs inside the Maya USB box, none of them is lit apart from the one that indicates power to the box).
Anybody got any idea how to make it work ?
Posted Tue 23 Aug 05 @ 2:19 am
I have it working I use MAYA44 USB. Test with the skin I made, that has bypass buttons for TC. "VinylTrack" https://virtualdj.com/addons/view.html?type=skin
Posted Tue 23 Aug 05 @ 11:50 am
DeeJay Ken,
Thanks a ton, it's working great with your skin :)
Now, if I may push the envelope a bit too far maybe, could I ask for a 1440x900 sized version ? That's the only thing stopping me to use it on the laptop...
Posted Tue 23 Aug 05 @ 5:45 pm
Hi!
Glad you liked the skin, yes I think I do a "widescreen" skin. I have orderd a new laptop and I belived that hade 1440x900. I will look into it it when I get the laptop, properly will add video into the skin as well.
I did a "Rane seratro scratch live" look a like, try it here: http://kennet.se/dwl/vinylscratch.zip
Posted Tue 23 Aug 05 @ 8:14 pm
this link doesnt work..can u fix it
Posted Sun 14 Oct 07 @ 9:37 pm
