Hi all,
The software is great.
However, each time the processor needs to "work" and therefore its fan is turned on, it causes a disastrous cut in the music during half a second.
This happen for example each time a song is being logged, when BPM and automix are selected.
Isn't there a system freeware which enables to have the processor always running at the same level and avoiding the fan to stop and restaart ?
Big thanks !
Big thanks !
Posted Fri 06 Feb 04 @ 12:43 am
What config are you running vdj with ?
Posted Fri 06 Feb 04 @ 1:48 am
try disabling hyperthreading and speedstep in your bios.
it worked for me.
it worked for me.
Posted Fri 06 Feb 04 @ 8:37 am
