Forum: Old versions
Topic: BAD Sound Quality! why?
I have only 1 sound card and when i mixing, the beats didn´t go or run well.. Why? It´s like the beats goes faster..
I didnt have this problem with Atomix 1.12.
Posted Mon 17 Dec 01 @ 7:17 pm
Try to disable 'Time Stretch' under the OPTIONS menu. I had the same problem once I upgraded to the new (and much, much better) version! I guess all the options are reset to the default settings when you upgrade. Hope that works! Good luck!!
Thanks. I´ll try..
also set the gain at normal... obvious but could be the problem
