ok heres the deal..i use 2 soundcards..
soundblaster 128 + Turtle beach montego
1) im using a external mixer and want to record the mixing...
i know that option isnt possible with atomix..what program should i use...so i can get the bass lowering i do between the fading...
2) is there a plugin where u can manage the bass, treble, gain? to atomix? or something similar...the most important part is the bass....cause the built in recording is good...but if u cant take away the bass...it doesnt sound too professional..
plzz if anyone can help me...answer here...i would really really appriciate it!..
/thx
Dj Gaz
/thx
Dj Gaz
Posted Fri 09 Nov 01 @ 7:09 pm
To record your mix, use www.waverec.de. It´s in german language, but easy to use. You can also choose to record directly to mp3. Just plug your mixer to the line-in.
For the bass, search on winamp.com for a good equalizer plug-in.
Posted Sat 10 Nov 01 @ 11:32 am
