please help. i made a 44 min mix of some songs and saved to a wav. file. When I burned it to my cd, it would not play on my stereo. It would only play on the computer under windos media. I noticed that since I was mixing there was only one track. can anyone tell me or help me out as to what I may or may not have done wrong? I have never had a problem making cd's and this is the first time. Is there a way or trick to inserting tracks? How do I get the next mix to play on a cd player.
Posted Sat 04 Aug 01 @ 6:41 pm
You can insert trax w/ a cue sheet editing program. I use a program called cdrcue. It makes .cue files that are compatible w/ the burning program _Fireburner_. I don't think there is any way to cue in trax with Adaptec software. I had to buy these other programs just so I could insert trax. It was not too expensive. cdrcue-$20.00 fireburner- $30.00. Hope this helps Ya.
Posted Sat 04 Aug 01 @ 8:41 pm
try www.cdwave.com
its a free wave splitting tool that allows you to see the song visually and set split points and best of all....its FREE!!!
Peace,
The Goner
Peace,
The Goner
Posted Sun 12 Aug 01 @ 7:42 am
