I have a numark platinum fx controller. If you know much about it you know it doesn't have a lot of knobs besides the eq high low and mid and maybe a couple more but I have Turnado vst and if you know about this plugin it uses lots of knobs. Right now I'm using the eq knobs on deck 1 and 2 to control it. High eq knob controls slot 1 on turnado deck 1. Ok I have the Turnado also in deck 2. Whenever I turn the eq high knob on deck 1. Slots 1 and two change on both decks. I don't like that I rather have eq high deck 1 control slot 1 on Deck 1 and eq high on deck 2 control slot 1 on the plugin. Is it possible to get this done? Im having issues figuring it out. What's the best way I can map this out? What's the best mapping that I can use?
Posted 5 hours ago
What script are you using?
Posted 4 hours ago
I dont know much about scripts. I just went in the mapping settings and made some adjustments Thought I just said the script. I don't know.
Posted 4 hours ago
you're using a script... unless you're using midi to vst...
Posted 4 hours ago
I using default just made a few edits. For numark and virtual DJ.
Posted 4 hours ago
give me the script you have for eq_high
Posted 4 hours ago
Oh ok I'm not in front of my computer. Do u know a script I can use that will work for this?
Posted 4 hours ago
I do, but I'm asking for what you have now to give you the right answer.
Posted 4 hours ago
I think it's eq high deck 1 1 which controls the spots on turnado slot 1. Something similar to that. Once I get back home I can give the exact one for each mid high and low.
Posted 4 hours ago
Effect active 1 1.
Posted 4 hours ago
just you and me in this thread, you don't have to go quoting replies
EQ_HIGH effect_slider 1 1
EQ_MID effect_slider 1 2
EQ_LOW effect_slider 1 3
Posted 4 hours ago
