Topic: HELP VDJ Problem in the Effect Engine
I wanted to make sure the problem wasn't on my side before I posted. Let me start with my Laptop specs, Im running a Lenovo I7 1.9GH with 32G of Ram. My OS is a Fresh copy of Windows 11 pro completely updated along with all firmware updates to make sure my laptop is up to date. Im also running a Lenovo I5 with 24G of Ram with a Fresh copy of Windows 11 and lastly a Dell Laditude with I5 and 16 G of Ram and a fresh OS as well. In all the computers I have, I have the same problem, when using my effects, there is a skip. The skip throws the timing off for as long as the effect is ON. When the effect is turned off the system will fall back to the correct timing. This started when I first updated to 2026 the Effects Engine was changed. Im still use the Legacy effects (Echo) Because of the lockout. But when u tried the New effects, (Echo Flanger, Reverb) I still get the same results. This has made using effects impossible. Has anyone else had these problems? I really need a solution asap. I do have a video if needed to show the problem. I just cant upload it to this post.
Posted Tue 28 Jul 26 @ 6:09 am
Upload to YT or dropbox.
I posted a link
What does your audio config look like?
If it uses send/return channels for fx then this can indeed add a delay for post-fader fx.
You can change fxProcessing to pre-fader
