Hi everyone, im using this line to control my mic with a poti with an Omnitronc cmx 2000 mixer with windows 11:
get hasmic ? param_greater 0% ? mic on & mic_volume & get mic_volume & param_greater 50% ? mic_talkover on : mic_talkover off : mic off & mic_volume 0% & mic_talkover off
If i move the poti, it turn on the mic and control the volume, if reaches 50% or more and it applies mic_talkover.
Ive tried to use mic_talkover 10% 1000ms to control the charasteristics of the talkover, but it doesnt work. With quotation marks, single ones, parenthesis, etc :D and it does not work. Only if i use it on a button works, but with a poti, only the on/off switch seems to work.
Thanks for your help.
Christian
Christian
Posted 2 hours ago
you're passing the float implicit from the dial to
as the 3rd param [STATE]
include a state
mic_talkover 10% 1000ms on
include a state
Posted 2 hours ago
