Forum: VirtualDJ Skins
Topic: Problem with skin blocks 2019 - 6 decks
Hello everyone, I'm new here! :)
I recently purchased the Pro Infinity license. I don't own a hardware controller yet, so I'm currently using my mouse and keyboard, but I hope to get a proper controller in the future.
I've noticed a few bugs while using this skin (and/or the software itself) and wanted to report them:
Bug #1: Pitch Reset Behavior
When two decks are playing simultaneously, the Pitch Reset button does not function correctly. Clicking it once only changes the BPM by 0.01 (up or down). If I double-click it, the BPM suddenly jumps sharply, which ruins the transition.
Bug #2: Automatic PFL on Track Load
Every time I load a new track into any deck, the PFL (Pre-Fader Listen / Cue) button activates automatically by itself, as if I clicked it manually.
Bug #3: Beatlock & Microphone Conflict
When Beatlock is enabled on a deck, engaging my USB microphone and speaking causes the BPM of the playing track to glitch out and suddenly jump to random values like 60 BPM or 140 BPM.
Has anyone else experienced these issues, or is there a known fix/script update for this skin?
Thanks in advance for the help!
Posted Fri 19 Jun 26 @ 3:03 pm
Hi everyone, a quick update after further testing with the default 4-deck skin:
Regarding Bug #2 (PFL Auto-activation):
I noticed this happens on the default skin too. Every time I load a track into an empty deck, it automatically triggers the headphone/cue (PFL) for that deck. I tried searching for "PFL" or "autoCue" in the Options menu to disable it, but couldn't find a setting that stops this automatic cue-on-load behavior.
Regarding Bug #1 (Pitch Reset):
This also happens on the default 4-deck skin, and I managed to pinpoint exactly when it happens:
If I blend a track from 122 BPM up to 138 BPM, it works fine.
If I blend a track from 138 BPM down to 122 BPM, it also works.
The bug only occurs when I try to reset/bring the BPM back to its original value while another deck is playing. It seems like some sort of "Sync Lock" or "Pitch Protection" is blocking the reset button and making the BPM jump or change by only 0.01. I searched the Options for "Sync" or "PitchLock" to change the behavior, but couldn't find the right setting.
Since I am mixing with a mouse and keyboard, these two issues really interrupt my workflow. Any advice on which internal settings can disable the automatic PFL and the Pitch/Sync lock would be greatly appreciated!
