Dear VDJ team,
In the past, I purchased VDJ Pro, and after an upgrade, I noticed that my license had expired. Yesterday, I bought a new license for a year and thought this would solve the problem. However, when starting up, I still see a pop-up in the bottom right corner of the screen stating that it is a demo that is valid for another 28 days. Can you explain to me why I still have a demo?
I have a registered account both on the website and in VDJ software. The DJ controller is a Numark Mix Track Pro, and it works properly.
Kind regards
Kind regards
Posted Thu 04 Jun 26 @ 10:43 am
You only appear to have a VirtualDJ Home Yearly subscription on that account, not a pro license.
So you still have 29 days of Pro Demo, after which you can continue using it with the Home license you purchased.
Posted Thu 04 Jun 26 @ 10:47 am
Thank you for the quick reply.
After the upgrade, I did indeed receive the Pro version. Does this mean that after 29 days it will switch to the Home version under my new license?
Posted Thu 04 Jun 26 @ 10:55 am
