Topic: Sound quality keeps dropping randomly
I dont know what to do. It sounds fine then become muffled randomly. Not it's not a CPU issue I have a brand new Dell 16 Plus. Im using a FLX10. My gear is high tier. So then what is it??
Posted 5 hours ago
Asio drivers ?
Which build of VirtualDJ?
Which version of Windows?
What is the latency / sound buffer size you selected?
Asio drivers ? Realtek(R) audio. Up to date
Which build of VirtualDJ? v2026 b9005
Which version of Windows? Windows 11 Pro
What is the latency / sound buffer size you selected? 256 samples/ 5.8 ms
sound config should be as follows, realtec isn't asio, it's default hardware driver for the laptop
On the djay Pro forum they do actually have a pre-filled section for when people post - and it rarely gets used properly. They either don't give the info at all, or they enter the wrong info etc.
Well. My sound config is the same.
