ROG GTX Strix
Processor Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (2.59 GHz)
Installed RAM 16.0 GB (15.9 GB usable)
System type 64-bit operating system, x64-based processor
NUMARK Mixtrack Platinum FX controller
AUDIO SETTINGS
Output-
Speaker + Headphone
Hardware-
Numark Mixtrack Platinum FX
WASAPI master channel 1&2
headphones channel 3&4
Getting NO sound...any thoughts? Thanks in advance.
AUDIO SETTINGS
Output-
Speaker + Headphone
Hardware-
Posted yesterday @ 5:17 pm
will get sound on speaker only from master channel 1&2
Posted yesterday @ 5:19 pm
Check that Windows is not using the Numark for system sound (which defaults to stereo).
Make sure Windows is set to Realtek (or similar) onboard audio.
Posted yesterday @ 5:28 pm
my system-sound-outpout is set to Speaker (Numark Mixtrack) as the default device. Is that not correct?
Posted yesterday @ 5:31 pm
here is what i think the issue is...VDJ 2026 has a regression bug with ASIO4ALL + USB Soundcard mode. Which forces my computer audio when it shouldn't. Any help further understanding this is appreciated. Thanks
Posted 3 hours ago
You didn't mention your use of ASIO4ALL. I would suggest uninstalling it.
Posted an hour ago
