Topic: audio sample when no pro license
Unfortunately, some people are abusing our licensing system, and have been using VirtualDJ FREE or HOME for professional events.
So, we have introduced a small audio drop just saying "VirtualDJ" that will play from time to time if you don't have a PRO license.
The audio drop sounds cool and should not disturb anyone playing at home, but if you are using VirtualDJ in professional events without a PRO license, you might want to get one now, otherwise your audience will know that you are cheating ;)
https://virtualdj.com/buy/
Posted Sun 07 Dec 25 @ 6:52 pm
And because we listen to our users, following your comments, we decided to change the way these audio drops happen.
Instead of having the audio systematically every 40mn or so, we changed that most sets will be without drops, just occasionally one drop might be played but rarely.
(we also lowered the volume of the drop, and made sure if it happens it won't be on recordings).
This way, home users won't be bothered, but if you try to take a free or home version to a public event, you *might* be ok this time, but one time you'll definitely get the drop, so better to get official and buy a license ;)
