My DDj Rev-1 is still having BAD sound Issues after NEW macOS Tahoe came out.
Posted Sat 13 Dec 25 @ 7:32 pm
0.3 ms latency seems a bit low, perhaps try to increase it
Posted Sat 13 Dec 25 @ 7:45 pm
how you increase the bit ?
Posted Sat 13 Dec 25 @ 7:54 pm
The latency value is in samples. You can click the X on the right side to reset it, or try 256 or 512
Posted Sat 13 Dec 25 @ 8:06 pm
i did 50+ sound better... ThankYou
Posted Sat 13 Dec 25 @ 8:14 pm
