Hello, today I ran into this problem:
On vdj status bar for a determinate folder I can see a certain number of file, eg. 835.
But if I open by file explore the same folder I see files are 840.
So my suspect fall into filename and in finally for one track I find that into filename are present double single quote without spaces in the middle( ' ' ) (eg: 12'').
So for a try, I have change the filename from " 12'' " into "12 inches";
VDJ recognize the new name without issue and status report 836 files/tracks.
Unlucky this is the only case that I really fix... And I still "lost" the other 3 tracks yet....
So my question, anyone know what limit have VDJ about char into filename?
I mean which are the char that i must avoid into filename so VDJ can recognize the track?
Or it's a regerssion ?
Mine is the v2025 b8909
Thank for help!!!
Thank for help!!!
Posted 3 hours ago
Are you on a MAC ?
Usually MACs are picky on "invalid" chars on the filename.
Posted 3 hours ago
PhantomDeejay wrote :
Are you on a MAC ?
Hi, thanks,
but no, I am on Windows and I am pretty sure that this not happens on previous version....
Posted 3 hours ago
