Does anyone know if there is a way to extend the capability of my setup, I have a denon mc6000mk2 which doesn't have any trigger pads, i also own an akai mpc drum pad usb. Is there a way i can connect both at the same time to VDJ and map say the stems to the drum pad whilst continuing to use the controller at the same time?
I'm on a macbook pro.
Posted 5 hours ago
Which Akai MPC model exactly ?
Posted 5 hours ago
