Hi everyone-
Hoping I can get some help. After about 6 years, I pulled out my MacBook Pro and Denon MC 6000 controller as someone wants me to play some music for an upcoming event.
I've gotten everything to work but an issue I'm having is the my channels don't seem to be controlling the correct song. For instance, I have a in deck 2 but the volume slider (#2 out of 4) seems to control the song in the right deck, where it used to control the song on the left deck. Not sure what I'm doing wrong as I've spent several hours trying different configurations and none seem to work. I have followed the instructions from here, https://virtualdj.com/manuals/hardware/denon/mc6000/setup.html and still can't get it to work.
In the past, I had it where I didn't use the cross-fader, I would just mix in by raising the channel volume while decreasing the other one.
On the back of the my mixer, I have the switches set to the following:
MAC
Mixing Mode = Int Mix
Output Source = Rec Out/Mic
Within VDJ I have:
Output=Speaker and Headphone
Hardware = DN MC-6000
Outputs
Master->Denon MC-6000-->Chan 1 & 2
Headphones->Denon MC-6000-> Chan 3 & 4
On my mixer:
Channel 2 knob at the top is turned to USB 1/2 Midi
Channel 3 know at the top is turned to USB 3/4 Midi
Front of mixer:
CH1, CH2, CH3, & CH4 are all set to through. and the X-Fader Contour is turned all the way to the right.
Any help is appreciated.
Nick
MAC
Within VDJ I have:
Outputs
On my mixer:
Front of mixer:
Nick
Posted Sun 23 Nov 25 @ 11:23 pm
I don't have mine handy but I think it should be on PC Mix. Int Mix is for hardware mixing.
Posted Mon 24 Nov 25 @ 1:49 pm
I figured it out, the MC-6000 has a button in the middle, towards the bottom that is called CF Mode, it needs to be clicked until only video is highlighted.
Posted Tue 25 Nov 25 @ 11:05 pm
