Hello!
I’m just about to make the setting for transitions which worked fine with one of my devices but the same commands do not work on another. This one is the one device I want to work with so I need a solution. I’d love your help if possible.
May it be that different interface causes issues?
I used a YT tutorial in which will be shown three different ways to make a transition. I entered the commands in the keyboard and saved them on different keys. The commands do work and I have checked if I did a writing mistake. Now I’m stuck my only idea is to reset vdj.
If you have any questions for clarification please just ask I’d be happy to answer them if possible.
Posted 12 hours ago
So what are those actions ?
Posted 4 hours ago
