Topic: One Library universal database - Page: 2
Phil Morse talks over the plus points and the minus points:
Unfortunately, there are influential ppl being actively disingenuous as commentors under the video too.
This industry really seems to be made made by marketing/who you can get to speak on your behalf.
Interesting discussion.
I'd be happy to be able to export from VDJ to my Prime Go, rather than having to screw around with Engine (of which I'm not a fan).
I wish Denon (inMusic) had just licensed VDJ and used that instead of developing Engine.
Yes to both points. You can use the CDJ export which the Denon players will read but it's a bit of a faff about.
DJ VinylTouch wrote :
The real issue to me is, given VirtualDJ already had this, why were they left out of the announcement?
According to someone that works there, it was and is an “unofficial hack” and not done the way they wanted I guess so VDJ doesn’t count 🤷🏾‍♂️
Hot Cues!
I'd like a simple system for setting hot cues using VDJ (my main software), and then export the tracks and hot cues to my Denon devices and to Algoriddim Djay Pro running on an Android tablet.
Where is the link to that comment?
They could have easily sent a cease and desist as it was marketed as a proper feature (there is a promotional video for it on VirtualDJ youtube page) for VirtualDJ and they work with Atomix on other things such as support of their own hardware.
"Industry wide partnership" etc is just rhetoric to say we blessed these vendors with using our format specifics and not others.
DJCU, Lexicon, Etc are all hacks too then - they just didn't come out with a promo video about it/are a business in the fields of general DJ software.
Also MixMasterG confirmed (and as @PhantomDeejay already said) that OneLibrary (as it exists currently, this can change in future) is just a rebrand of the newer library - Device Library Plus
It only makes sense - current hardware already works with it without a firmware upgrade...that could really only be possible if, it was a really a new format, the firmware already had the functionality to understand it since at least the last firmware release of the hardware or it's the same library format.
So... the "One" library to rule them all must be licensed!
Cool! At leasts the masks have fallen.. :)
I see. Not much to see there - one set of providers got the blessing the others have to ask and/or wait for it 🤷🏾‍♂️.
Btw this was one of the most requested features of current time on their forums, and it's was well known on that post that it already works across here. I guess they have to give appearance of forefront (stems implementation had the same debut) so it happened this way.
