Topic: Error Stem Engine
Recently, Virtual DJ has been causing the following error.
The message "Stemengine Error" sometimes appears.
Then it automatically sets the option "Don't use GPU" in the options.
The CPU then also takes over.
It wasn't there before, only since version 8800.
My graphics are RTX 3060.
Posted yesterday @ 6:07 pm
Solved .
I have install new Nvidia Drivers , and musst restart the System after this .
After Restart this works again.
But now have an other error .
Wenn I try an new FX to Effectslot 2 than VDJ crash and restarting .
But only this Slot and Deck 1 .
Solved
