I’m using a Pioneer DDJ FLX4 with VDJ and I’m having an issue where there is no sound coming from the headphones when I cue a track.
I’ve tested & confirmed with Rekordbox that everything hardware-related is fine & I can cue there with no issues, it’s only in VDJ.
I’m using a Windows 11 laptop and the sound settings seem to be correct … master is “2 - DDJ FLX4 (WASAPI)” on channels 1&2, and likewise for the headphones which are set to channels 3&4.
I’ve tried changing the channels to 1&2 for both master & headphones but still the same issue.
Any ideas what I’m missing?
Posted Tue 19 Aug 25 @ 2:39 pm
Sorry, I’ve cant get the images to embed but here are my sound settings:
https://jottacloud.com/s/429d167041f51a2478cb0523fda551cb40c
And the controller:
Thanks in advance for any help
And the controller:
Posted Tue 19 Aug 25 @ 3:05 pm
Hello,
Try changing from OUTPUT ---} HEADPHONES from DDJ FLX to HEADPHONES(name of your headphones for example RB-HX2208), then hit apply.
Posted Tue 19 Aug 25 @ 7:55 pm
the audio config looks fine
make sure windows is not using the flx4 as default sound device
Posted Tue 19 Aug 25 @ 10:50 pm
Thank you for the responses - turns out that the controller was faulty!
When I connected external speakers via the phono out, there was no sound from the controller either from VDJ or Rekordbox.
So I returned to the store (Argos), got a replacement, went home & plugged it into the laptop - worked first time without changing a thing, both for cueing and also phono out.
Very glad I bought in-store rather than online this occasion!
Posted Wed 20 Aug 25 @ 2:33 pm
