Hello VDJ community, how’s everyone doing?
I had a quick question and was hoping someone might help.
Is it possible to assign different effects to the STEMS effects pads for MELODY, BASS, KICK, and HI-HAT simultaneously?
Right now, I have one button that applies an ECHO OUT effect to the instrumental part of a track, and another that does the same for the vocal part. While I’m happy with the vocal ECHO OUT, I’m not really a fan of how it sounds on the instrumental.
So I was wondering:
Is there a way to create a button that applies a VINYL BRAKE effect only to the instrumental part of a track? I'd like also to configure within the button the lenght of the Vinyl brake effect.
Any advice or tips would be much appreciated—thanks in advance!
So I was wondering:
Posted Mon 04 Aug 25 @ 3:25 pm
Sure
padfx 'vinylbrake' 1bt 50% 50% 0% 'stemfx:MeloRhythm'
Posted Mon 04 Aug 25 @ 11:35 pm
Thank you Alex!
Is there a way to make the time a fixed number of ms instead of based on the beat? I tried making a script that uses get_bpm to calculate the beat value based on the desired fixed ms of brake time, but was unsuccessful.
Posted Tue 05 Aug 25 @ 3:21 am
AlexRdZaik wrote :
Sure
Thanks! I will try it and let you know!
Is there a way to make those effects post fader too?
Posted Tue 05 Aug 25 @ 5:50 am
vinyl brake is a position fx it is always prefader.
Posted Tue 05 Aug 25 @ 7:17 am
Yes I was thinking about Echo Out...
Posted Tue 05 Aug 25 @ 7:33 am
Set fxProcessing setting to "post-fader"
Posted Tue 05 Aug 25 @ 8:29 am
But this affects all effects... I was wondering if I could add a command to that script above...
Posted Tue 05 Aug 25 @ 8:31 am
interceptintercept wrote :
Thank you Alex!
You could add effect_bpm_deck X, to have a fixed braking time on all songs, but I think it would affect all effects as well.
Posted Tue 05 Aug 25 @ 10:55 am
No, there's no way currently to have "some" effects operate in post and some in pre fader mode.
You CAN add a command on the script to switch fxProcessing to post, but you'll have to somehow "remember" to later revert it back to pre. Most likely with a repeat script. However while the fxProcessing is set to post, ALL effects will run in post as well.
Yes it will override the timing of ALL effects.
However, you can use "BrakeStart" effect instead that it's parameter is in seconds and not beats. padfx 'BrakeStart' 25% 'stemfx:MeloRhythm'
Posted Tue 05 Aug 25 @ 12:07 pm
Thanks VDJ fam!
Posted Tue 05 Aug 25 @ 12:08 pm
"You CAN add a command on the script to switch fxProcessing to post, but you'll have to somehow "remember" to later revert it back to pre. Most likely with a repeat script. However while the fxProcessing is set to post, ALL effects will run in post as well."
Which is the code ? So I can add it to this script and test
Can you please provide us with the code to put back the effects to pre?
I have a Stem reset button and I can add that action.
For reference this is the code for STEM RESET button I have:
thanks in advance!
padfx 'ECHO-OUT' 1bt 50% 50% 0% 'stemfx:MeloRhythm'
( stem_pad vocal ? : stem_pad vocal ) & ( stem_pad instru ? : stem_pad instru ) & ( stem_pad bass ? : stem_pad bass ) & ( stem_pad kick ? : stem_pad kick ) & ( stem_pad hihat ? : stem_pad hihat )
thanks in advance!
Posted Wed 06 Aug 25 @ 9:21 am
setting 'fxprocessing' 'post-fader' & padfx 'ECHO-OUT' 1bt 50% 50% 0% 'stemfx:MeloRhythm' & wait 5000ms & setting 'fxprocessing' 'pre-fader'
( stem_pad vocal ? : stem_pad vocal ) & ( stem_pad instru ? : stem_pad instru ) & ( stem_pad bass ? : stem_pad bass ) & ( stem_pad kick ? : stem_pad kick ) & ( stem_pad hihat ? : stem_pad hihat ) & setting 'fxprocessing' 'pre-fader'
Posted Wed 06 Aug 25 @ 11:16 am
Tomorrow I will test it 🔥 thanks!
Posted Wed 06 Aug 25 @ 11:34 am
AlexRdZaik wrote :
Sure
It works perfectly!!! thanks!
Can you paste the origial code without &apos atc etc?
Thanks
Posted Thu 07 Aug 25 @ 6:13 pm
[quote=AlexRdZaik]Sure
Unfortunately it's not working...
Posted Fri 08 Aug 25 @ 6:06 am
It doesn't work because the effect is named "Echo Out" and not "Echo-Out" with a dash.
I just amended to your script. I didn't proof read it.
Anyway, try this:
setting 'fxprocessing' 'post-fader' & padfx 'ECHO OUT' 1bt 50% 50% 0% 'stemfx:MeloRhythm' & wait 5000ms & setting 'fxprocessing' 'pre-fader'
Anyway, try this:
Posted Fri 08 Aug 25 @ 6:12 am
Anyway, try this:
Anyway, try this:
Finish my coffee and will try it again...thanksssss!
Posted Fri 08 Aug 25 @ 6:13 am
Anyway, try this:
Anyway, try this:
It doesn’t seem to work… but I’ll manually set the effects post-fader whenever I need them.
I was wondering if you could help me better understand the parameters for the ECHO OUT or BRAKE FX effects. I’ve checked the script description page on the VDJ website, but I couldn’t find a detailed explanation of these parameters.
My main goal is to make the effect—BrakeFX in this case—a bit louder, as sometimes I can barely hear the instrumental and melody slowing down and stopping.
Any help would be greatly appreciated.
Posted Fri 08 Aug 25 @ 2:38 pm
