Topic: Vdj 2025 BPM problem - Page: 2
The issue has been found, and affected only mac with ARM cpu's, a fix will be available soon.
Good news, thank you for help!
Ssorin wrote :
jccalmet wrote :
Its pretty complicated to explain. Some BPM just go wild high when you scan or even BPM editor. the only way to fix it is to do it manually and not scan at all, but maybe its not VDJ problem i thinks it might be a mac issue i deleted the current version and tried version 8553 & 8528 it seems to fix some of the songs but still have the high bpms on some of them. Maybe its a mac update that mess up the whole thing. as of right now if you have an old drive and old mac just don't update anything. i'm just doing it manually of the songs that i needed for the event, but its a lot of work.
What model of mac do you have? M max version? Or just M?
I have an M1 and M3 the M3 is the one with the issue
Build 8626 now available in Early Access
I have the same problem, v2025-m b8678 on an M4 Max - if I reanalyze the whole library will it fix it if b8626 had a fix?
yes
Still having this issue. MacBook Pro with M1 Pro. I've just been dealing with this for a while now. Before beats used to sync up automatically and correctly. Now I have to manually beat sync each song to where the BPM ends up having decimals. Some songs have the BPM at 160 when they should be at 80. I set que's for songs or saved loops and when I hop back on the app, it completely resets everything. I've set all the above before events and when I'm at the event and play songs, everything I manually did was gone.
