Forum: VirtualDJ Skins
Topic: A teaser, and more.. - Page: 3
So, the skin is now available for download.
https://virtualdj.com/plugins/?addonid=81906
Since it's a complex skin, I'm going to make a manual of sorts..
There's much more than meets the eye..
A good way to explore functions is to have tooltips enabled. At least until you get familiar with the skin
 Selected as best answer
Quick setup for a wedding tomorrow night so I will have to use Denon standalone (yuck) but I'll definitely give it a spin next weekend. Looks amazing!
thanks for you hard work on this look perfect so far
Thank you for putting in all that work on the skin and releasing it with instructions/a manual...looking forward to learning about and using it 🍺
Any chance you could look at the "prep" screen and add some "fluid or rigid" scan buttons??
I use the prep screen all the time.
Yes, I have something in mind. But it will take some time since currently I'm busy with other projects.
Give me 10 days..
Awesomeness!! I'll be waiting and Thanks!!
