Hello,
I just bought a DDJ SB3 - new - i downloaded the firmware and installed it. Everything was working as it should but the volume of the headphones is too low , you cannot hear enough.
Tried with 3 types of headphones, all the same , low volume.
Can someone help me with this problem, how to solve it ?
Posted Fri 14 Feb 25 @ 8:40 am
Try changing the headphonesGain setting in small increments to see what happens. I'm sure it's set to 0.50 by default so try 0.55 to see if it's any better.
Posted Fri 14 Feb 25 @ 8:48 am
Thank you
Posted Fri 14 Feb 25 @ 12:09 pm
