Hello .
I am using a Akai apc Mini to trigger my samplers , it was working fine until the last few updates.
The problem is :
The bottom pads stops responding and then top row pad 1 to 8 behaves likes the second row (triggers samplers from 9 to 16 ) and so on until the last row stops responding.
I try all the possible settings in the sampler options but nothing works .
The pads works fine for a while then the bottom row sttops responding and the works fine for a while a then don't etc.
I am using VDj V2025 b8502 and Pionner ddj 400 .
The samplers works fine in the controller deck 1 triggers samplers 1 -8 and deck 2 triggers samplers 9 - 16 while the Akai apc mini only works fine for a while .
I have been using this set up for a long time and it was always working fine until i decided to update a month ago and now I have this problem .
I hope you can help me .
Regards.
The problem is :
Regards.
Posted Wed 29 Jan 25 @ 2:14 am
I'm having the same issue. Just bought it and now my pads only start at 9 instead of 1.
Posted Wed 05 Feb 25 @ 11:30 pm
You have SamplerSpanAcrossDecks setting to Yes ?
Posted Thu 06 Feb 25 @ 1:02 am
