I was hoping someone could help me figure this out. For some reason, my DDJ-FLX10 seems as though my cue points are snapping to the beat grid when I try to set them. My workaround thus far has been to use the trackpad on my laptop to set my cue/hot cue point, but that gets hairy when I am in a hurry.
What setting am I missing in VDJ to allow me to set the cue point nearly anywhere using the jog wheel? The reason I am asking is because snapping the cue points to the beat grid doesn't work so well when the beat grid doesn't exactly line up to the song.
I also use an associate's DDJ-1000 on this same laptop and I can use the jog to put the cue point anywhere I want, regardless of the beat grid.
The machine in question is a 2024 model Asus Rog Strix G16 with Windows 10, 32 GB of RAM, RTX 4070, and a i9-14900HX processor running the latest build of VDJ.
Posted Mon 20 Jan 25 @ 1:37 pm
search settings for "quantize" see what it brings up.
Posted Mon 20 Jan 25 @ 3:01 pm
There shouldnt be any difference in setting Hotcues between those controllers or mouse/keyboard/screen, if you have the same VDJ Settings.
Perhaps the Quantize button on FLX10 (Nr. 43 https://virtualdj.com/manuals/hardware/pioneer/ddjflx10/layout/decks.html ) was manually enabled ?
Posted Mon 20 Jan 25 @ 3:13 pm
It was the cueloopAutosync box that was checked. I unchecked it and I can move the jogs wherever I want to regardless of the beat grid.
Thanks for the recommendations!
Posted Wed 22 Jan 25 @ 3:26 am
