New up date has stopped me using my samples on loop and I have to hold down so beats play any help would be nice
Posted Mon 02 Dec 24 @ 7:55 pm
Posted Mon 02 Dec 24 @ 8:24 pm
If it was not broken why fix it
Posted Wed 04 Dec 24 @ 5:50 pm
This has not changed with 2025,different trigger nodes have been there since the first release of vdj 8
Posted Wed 04 Dec 24 @ 5:57 pm
Something was done to the Sampler. Not sure what but, but after i updated I hit the same sampler pad i always hit and got no response. Had to go in and redo some settings in the sampler menu. Update moved my samples around to different pads.
Posted Thu 05 Dec 24 @ 3:29 am
Hi, after the update my saved pads on Akai APC mini moved up one line and other saved samples do not display all the pads to continue saving on 64 pads. Can you tell me how to fix this or is this an update issue?
https://drive.google.com/file/d/1VNjJ1b7wq2DEEY3qhMC6I5YRDJe9oyzP/view?usp=drive_link
https://drive.google.com/file/d/1i7lutAP2pQ_mPrXKH7VemScNiI9Qtb1M/view?usp=drive_link
Posted Sat 07 Dec 24 @ 10:40 am
Yes, some users may find that samples that were once visible on the skin pads are now not.
What I've been doing is checking the XML file for each bank and ensuring that the slots for each sample are sequential, starting at zero.
Posted Sat 07 Dec 24 @ 2:35 pm
can you post the content of the xml file of a bank that changed in the new version, so we can understand the problem?
(select "edit bank in browser" to show the bank in the browser, then right click on it and select "open in explorer" and locate the file with your bank name and .xml extension)
Posted Sat 07 Dec 24 @ 5:39 pm
Who are you asking?
I just worked on one earlier, that didn't have slot mentioned in the XML. I've added slot="X" now, and overwritten the original - but I think it had 'row' instead.
Posted Sat 07 Dec 24 @ 5:51 pm
If the xml has no slots (because it was made in vdj2024), VirtualDJ 2025 will automatically set slot=row*maxcol+col
VirtualDJ 2025 doesn't have any notion of columns or rows anymore (we keep writing col="" in the xml only for backward compatibility in case you want to revert to vdj2024 for a while).
It's only slot numbers now.
pads always have 4 columns on the skin. and the sideview depends on the available space, but can be locked to a specific number of columns in the menu.
Posted Sun 08 Dec 24 @ 6:54 am
https://drive.google.com/file/d/1o6gVSYllbV4_j-ehz1xl2uiVPs-4TTam/view?usp=sharing
This is the content inside the xml file after the update.
Everything is shifted on the device one line up.
Akai APC mini device.
Start slot="0" col="0" should I start with 1 and 1 or what should I change?
Posted Mon 09 Dec 24 @ 3:36 pm
As mentioned earlier, start the slot number at zero and count up from there (next sample slot="1" etc).
Posted Mon 09 Dec 24 @ 3:47 pm
Your samples start properly with slot=0 and looks like this here ...
Is this how it looked before the update ?
Posted Mon 09 Dec 24 @ 3:56 pm
it starts from scratch. I gave access to the file via the link. I don't understand what I need to pay attention to, that's why I'm writing.
Posted Mon 09 Dec 24 @ 3:57 pm
It still looks the same as yours. It just doesn't display correctly on the controller.
Posted Mon 09 Dec 24 @ 4:00 pm
Same with factory default Mapping ?
Posted Mon 09 Dec 24 @ 4:04 pm
when choosing factory default no changes
Posted Mon 09 Dec 24 @ 4:10 pm
I am ready to do everything anew, but earlier when the controller was turned on, all available 64 buttons in the sampler were automatically displayed, and now the mode automatically shows 4 cells, I can set the location of 8 pads, then 16 will become available. Is it possible to add this in the menu? Or only manually in xml by replacing?
Maybe I'm don't understand something. Sorry!
Posted Mon 09 Dec 24 @ 4:32 pm
Result of this dialogue is nothing, next time I will think before clicking update this virtual dj.
Posted Tue 10 Dec 24 @ 9:27 pm
This is what i get with your Bank and AKAI APC Mini MK2
Really not sure what happens in your system
Posted Wed 11 Dec 24 @ 5:40 am
