anyone with rane four controller, if so what are your ASIO set on to keep the music from crackling. i have a dell gaming laptop with all the bells and whistles. i only have this problem when i use the rane four.
Posted Tue 05 Nov 24 @ 9:14 am
There is no "one size fits all" setting for ASIO, even if others have the Rane Four.
You have to adjust it yourself, so that it works for you.
Posted Tue 05 Nov 24 @ 10:51 am
Also run a DPC latency check as some of the Dell "support" apps can cause issues with real time audio and should be uninstalled.
Posted Tue 05 Nov 24 @ 11:14 am
I have a Rane Four, a dell and I use krk 8 fourth generation, I have no problems. there is a latency setting in rane.
Posted Wed 06 Nov 24 @ 12:19 pm
