Hi, I tried looking online and through here to see if this had been posted but I didn't see anything nor do I think it's possible but I thought I'd ask. I have the Pioneer Flx 10 controller and learned that it has dmx campabilites with rekordbox however I've used virtual dj all my life.
Is it possible to use the Pioneer flx 10 dmx output into anything in virtual dj like is there any plugin or software or setting that can do or do "similiar" like the dmx that you can do in rekordbox?
I saw that the software analyzes the track and creates a "show" for you after setting up your lights.
Posted Mon 20 May 24 @ 2:05 am
Based on the DDJ FLX10 hardware manual, the output is not mapped/used by VirtualDJ. It also isn't (currently) used by Serato either.
This is probably because most other DJ software do not have lightshow creation + DMX universe manipulation built in. It also is a way to give Pioneer/AlphaTheta a minor competitive advantage against a solution of competing DJ Software + Lightshow Software setup.
Posted Mon 20 May 24 @ 4:22 pm
Not directly from RB built in lights.
But VirtualDJ works with a wide range of DMX solutions, like SoundSwitch and more.
short guide and demo here as well
https://www.youtube.com/watch?v=KrXPjoOZ1Qo
Posted Mon 20 May 24 @ 4:35 pm
And there are DMX interfaces that support OS2L that lets you control DMX lights, scene, etc from within VirtualDJ
See here:
https://virtualdj.com/wiki/OS2L.html
See here:
Posted Mon 20 May 24 @ 4:36 pm
Thank you this is very helpful, I appreciate the reply
Posted Fri 31 May 24 @ 8:51 am
