Hi together,
I do have two controllers (Denon MCX8000 and Traktor Kontrol S3). Sometimes I want to use the both at the same time on one pc (macbook, if relevant). Controller 1 should control decks 1 and 2 and controller 2 should control decks 3 and 4. I can achieve this with the mapping (but would not bother me, because they are both 4 channel controllers) but i can not switch the decks independently. The controls (Play, Cue, Hot Cue, etc.) on both controllers control the same deck. If I press the switch decks button (from 1 to 3) both controllers are switchting the decks. So I can control the same deck on both controllers at the same time. Is there a possibility to control the decks separatly? So when switching on controller 2 from channel 1 to channel 3, controller 1 would stay at channel 1 an can control it.
Posted Wed 27 Mar 24 @ 11:52 pm
