As of v2024 b8017
- Drag and Drop of folders to the Sideview now depends on lockFolderOrder
I can no longer drag and drop playlist folders to the sideview while lockFolderOlder = yes.
Older builds allowed drag and drop of folders regardless of the status of lockFolderOrder.
I think the older behaviour makes more sense (what does lockFolderOrder have to do with the sideview orientation? The order of the sideview can't be dragged around anyways) - VirtualDj still doesn't detect my Filter Folder structure in Folders/Filter
Only the top level Virtual Folders are shown with a tree expander icon, but when the expand icon is clicked, it disappears amd nothing happens.
The changelog notes claimed this should be fixed.
Posted Fri 22 Mar 24 @ 12:06 am
DJ VinylTouch wrote :
As of v2024 b8017
both have been fixed in the latest EarlyAccess version (b8019)
Posted Fri 22 Mar 24 @ 7:43 am
I've confirmed that both issues are fixed in b8019 šŗ.
Posted Fri 22 Mar 24 @ 1:57 pm
It seems that this build also broke/changed behavior of the respecting of timecode_reset_pitch/general pitch on loaf for DVS - it wasn't working for me on a stream I did two hours ago and it also seems like loading a deck in general had a skewed pitch on load
Posted Fri 22 Mar 24 @ 6:45 pm
So I found the problem was that somehow, my settings.xml got corrupt again (using a fresh settings.xml didn't show the problem). I manually diffed to recover everything and then made a backup. I'm not sure how the corruption happened - I kept the original settings.xml file that had the problem for reference.
Posted Sat 23 Mar 24 @ 6:15 pm
ā¦have you problem with sampler pad? now in sampler pad name i canāt read sample name but i read script about nameā¦and you?
for example in PAD1 NAME sampler pad editor my script is: āµloaded ? get_sampler_name 1 : get_text āvuotoā āµ
now i read in PAD1: get_sampler_nameā¦.
is possible is there a bug with āµāµ?
thanks
thanks
Posted Sat 23 Mar 24 @ 10:51 pm
Seems to work fine in the default sampler pad page, so probably some typo in your own?
Could be a copy-paste problem, but at least in the script you posted here, there's 2 problem.
The backtic character used is wrong, it should be `
And also, the correct script is get_sample_name, not get_sampler_name
Posted Sun 24 Mar 24 @ 5:04 am
in sampler pad editor my NAME script is:
`sampler_bank 'recordings bank' ? sampler_loaded 1 'auto' ? var 'choose' 1 ? get_text "`sampler_mute 1 'auto' ? get_text '(mute)' : nothing``sampler_volume_nogroup 1 'auto' & param_cast 'percentage'` `get_sample_name 1 'auto' & param_cast 'text' 11`" : get_sample_name 1 'auto' : var 'recmode' 0 ? get_text 'rec Master' : var 'recmode' 1 ? get_text 'rec Deck' : var 'recmode' 2 ? var '$mictype' 0 ? get_text 'rec Mic' : get_text 'rec Linein' : nothing : sampler_loaded 1 'auto' ? var 'choose' 1 ? get_text "`sampler_mute 1 'auto' ? get_text '(mute)' : nothing` `sampler_volume_nogroup 1 'auto' & param_cast 'percentage'` `get_sample_name 1 'auto' & param_cast 'text' 11`" : get_sample_name 1 'auto' : nothing`
in version b8017 doesn't work :( i read "sampler bank..........."; in version b7831 i have installed and previous it works....for this i think it's changed something in "writing script"...right?
Posted Sun 24 Mar 24 @ 3:41 pm
Will the VDJ2024 version install into the same folder/directory of v2023 or will it install into a separate folder/directory so we can use both versions or will it overtake the V2023 folder/directory.???
Posted Mon 25 Mar 24 @ 4:07 am
It's just an update from the good old VDJ 8 code base with a new marketing name (and of course the announced added features)
So it will overwrite just like any other update, unless you manually keep 2 versions
Posted Mon 25 Mar 24 @ 4:25 am
Good to know, Thanks.!!!
Posted Mon 25 Mar 24 @ 3:30 pm
hey with last update b8055 (standard log) problem with PAD name script is solved! Wow šš
Posted Mon 01 Apr 24 @ 7:57 pm
