HI,
is it possible to decouple Tabs?
I would like to show the Automix and Linked Tracks tabs both at the same time, either stacked or side by side.
Thanks
Thanks
Posted Thu 29 Feb 24 @ 12:39 pm
That would need a skin edit, and I'll be honest, custom browsers is one the the most confusing parts of skinning I've run into.
but I made it for karaoke users, 4th window is automix
Posted Thu 29 Feb 24 @ 12:55 pm
Thanks for the insight.
Tbh I would want to prevent custom skins, for not running into compatibility issues when the default is updated in the next versions. I will try to place this then as a feature suggestion.
Posted Thu 29 Feb 24 @ 1:04 pm
