My backup Mac (apple M1 Pro) same specs as my main mac when i open Virtual gives me this error!
I did a migration from the main Mac to this one. Has anyone had this issue and did you find a fix for it?
Posted Sun 31 Dec 23 @ 3:18 am
I'm sure I read there's an issue if you use the migration tool, a bug on the Apple side.
The machine needs to be set up manually.
Posted Sun 31 Dec 23 @ 9:38 am
Thats what I figured! It worked fine before that, thank you for your vast knowledge sir!!
Posted Sun 31 Dec 23 @ 2:07 pm
