Like making an automatic loop and not a manual one.
When the song is loaded, the automatic loop is turned on so that I don't need to do it manually every time
![](/img/396975/80504/Untitled-11.jpg)
Posted Fri 29 Dec 23 @ 8:22 am
look at the poi editor
Posted Fri 29 Dec 23 @ 1:37 pm
Yes - Thank you - Thank you - Thank you - Thank you - Thank you -
Posted Fri 29 Dec 23 @ 2:28 pm
