Topic: Opposite script for vocals only
Hope it's not a bother but I need some help.
repeat_start vocupdown ? repeat_stop vocupdown : stem vocal 0% ? repeat_start vocupdown 5ms 50 & stem vocal +1% : repeat_start vocupdown 5ms 50 & stem vocal -1%
Mapped to a key this script does instruments only up down gradually and works fine.
I need one for vocals only the same way the above one functions. I've tried but can't seem to get it.
I would also like if this functions on the default deck rather than the active deck when i press the key.
I would really appreciate the help. Thanks.
Posted Thu 10 Aug 23 @ 6:05 pm
try fullvocal
just vocal is for 5 part stems, for ez it's fullvocal, and modern it's melovocal
as for the deck
you have
deck master
deck active
or the not selected deck
deck 1 select ? deck 2 stem thing : deck 1 stem thing
shouldn't your compare be 50%?
I have tried. Possible for you to write a full correct working script for me?
deck 1 select ? deck 2 repeat_start vocupdown ? repeat_stop vocupdown : stem fullvocal 50% ? repeat_start vocupdown 25ms 50 & stem fullvocal +1% : repeat_start vocupdown 25ms 50 & stem fullvocal -1% : deck 1 repeat_start vocupdown ? repeat_stop vocupdown : stem fullvocal 50% ? repeat_start vocupdown 25ms 50 & stem fullvocal +1% : repeat_start vocupdown 25ms 50 & stem fullvocal -1% :
You are a GENIUS. Wow. Thank you Thank you...Your script works better than all the crap I made..lol. Have a good one my friend.
