Topic: Better smart mapping for keyboards or other unsupported midi controllers
as the title says,
a way to map things like the MPC mini series or the M-audio Oxygen 49 keyboards or any other midi controllers , to use with effects and things just as dj controllers.
Also a better ui and or way to map keyboards to vsts, so far ive been unsuccessful, but im most likely doing something wrong,
regardless a better way to do it would be fantastic.
Posted Sat 20 May 23 @ 5:08 am
If you by "smart napping" mean limited mapping options to make it even simpler, then I'm not a fan
I like that VDJ can so so much more than any other DJ software
But if you mean mapping of unsupported hardware in general, then I'm a huge fan. The scripting language in VDJ is one of the best things in the software. That's how any pro software should work
Anyway...
Standard mapping like having a button or a knob doing something standard, like something you can also click in the skin, is simple. And very "smart" :)
Here is an example of me mapping an m-audio oxygen midi keyboard:
Regarding vst FXs or even vst based virtual instruments, you can send your midi inputs right trough to the fx - and then remove it from your own mapping, to not have double triggering.
Here is an example:
