Topic: Stem mixing with DDJ-SZ
Hi DDJ-SZ users,
If you are mixing stems and it sounds weird it is probably due to the built in hardware EQs are still working in addition to your stems. Go into you audio setup and change you output assignments from deck 1 -1/2, deck 2 3/4, deck 3 5/6 and deck 4 7/8 to master out - 9/10, headphones -5/6.
This setup will send the output of VirtualDj Direct out. The master.
Here is a crude video demonstration: https://youtu.be/9D4kJE4sGsQ
Posted Sun 07 May 23 @ 3:34 pm
I would not advise anyone to do this.
With SZ you can use Stems for decks 1 & 2 by using the EQ controls of decks 3 & 4.
Messing with sound settings like this will cause several unwanted side effects, such as loosing COLOR effects.
