Forum: Addons
Topic: Project Control - Page: 4
Version 1.0.6 - 2023-04-29
bugfix - Custom Buttons on Variation Middle and hide Center.
bugfix - Video Link don't work (Cover/Video drop)
add - Layout 4 Deck - Performance 2
add - Layout 4 Deck - Vertical not mirrored
change/remove - dropzone Deck Color Overlay
@Blingballer This looks like that the Variable '@$skincolor_23' had a not existing Value
'@$skincolor_23' 0 -> flat
'@$skincolor_23' 1 -> daylight
'@$skincolor_23' 2 -> contrast
There are any Solutions to fix this.
1. go to the Vistual DJ Settings and search the Options VDJScriptGlobalVariable
Search at the line $skincolor_23 and set the Value to zero $skincolor_23=0=0.00000
2. map a Key or Custom Button with the Scipt multibutton 'resetskin' This reset my Skin to the factory default. (works only when my Skin loaded)
3. map a Key or Custom Button with set '@$skincolor_23' 0 & load_skin to set the Variable to zero.
The question is. How did you set the variable to an incorrect value.
Thank you!
This happened switching from one saved preset skin to another. It seems that if I save a preset with the hideBrowser option and switch to that skin from another saved preset, that's what happens. I was able to fix it by clicking 'show Browser window', switching to that skin, remove hideBrowser, switch again, and switch back.
I'll also try your method if it happens again
@Blingballer
Set the Skin to your favorite settings and re save your Presets. I think you're presets are wrong saved.
Never knew there was an XY view for the fx in VDJ ( along with some other lil features) till i saw it on this skin. I'm kinda stuck on this skin even tho i hv recently claimed Vanced GT to be my fav..... but i hv to give credit here... F'n AMAZING!!!!!
Job well done @Denyo
Ive noticed in this skin and Controller 2020 that the beat counter at the top is not really done correctly. If you look at the default skin it will show how to count beats and bars correctly.
What do you mean with, it count not correctly?
I found a bug in Project Control (not Controller 2020). The circle of deck 1 was not show. But the number of beats is correct.
default
Project Control
the count should be 1...............2.............3...............4 <-----represent the longer top bar whole note
...................................1 2 3 4.....1 2 3 4....1 2 3 4......1 2 3 4 <----represent the shorter quarter note
This is beatcounter 16
The top 4 counter shows not bars, it shows the 4 beats of one bar.
The botom 16 counter shows the 16 beats of 4 bars.
This is what I want to see and have found useful for years. Don't forget it's my skin and i have things in this skin they i need and use.
I can include a option to set the 4 counter to the first beat of phrase 16.
I think you mean this:
Sorry I said note instead of bars but still how did you get it to do whats in your clip...mine doesnt move like that. This is in phase.
i have change the verbs in the skin.xml. I add it native in the next update
My friend your new skin is amazing but i dont know...project control is locked
Good afternoon DENNYO!
Your work is great, my tracks are from the 80s/90s, and their grid is not accurate because of this wanted to see if you have the option to take those markings on beatgrid because in this case only gets in the way and do not have the need for them?
I'll send a print.
Thank you!
@reginaldo87
You will hide the Gride complete? Have I understood that correctly?
good afternoon!
I wanted it to stay like this.....
gridlines off
Version 1.0.7 - 2023-08-05
bugfix - Phrase Circle on Beatcounter (Topzone) of deck 1 don't show
add - change direction of the Pitch Fader
add - Bars/Beats Counter 4/16 on Topzone
add - Info Window
add - toggel the Browser zoom Button to a Custom Button (Topzone)
add - the 2 Deck Layouts can now use as 4 Deck swapped (Skin/Number of Decks)
add - enable/disable the Lock Skin
Thank you for this skin.. it is awesome!
I was wondering if it would be possible to make the Songinfos section a little larger. The Rating Stars are cut off (it only slows about 4.25 stars) and any custom info like Remix or Comments displays very little information. It would be great if we could see a bit more there.
Version 1.0.8 - 2023-11-26
bugfix - the phase circle on 4 deck wrong sort.
add - change the sort behavior of the Beatcounter WAVE or MIXER
add - on exit script to stop repeat scripts from the Skin
change - updated the Wall of Supporter
change - Songswave half to the new native child half="yes" works only later than BUILD 7735 (2023-10-23)
66%
