PAD_MODE_HOTCUE_LONG interferes with the responsive splitting of the 8 pads for everything that involves the PAD_MODE_HOTCUE button. So for example Hot Cue split with Pad FX or Beat Jump or Sampler...
When PAD_MODE_HOTCUE_LONG is deleted, the split works just fine.
Can the FLX_10 MIC effects mapped to something else in the default mapping?
Posted Fri 28 Jul 23 @ 12:55 pm
Hey all- what is the current status with the FLX10 and VDJ? Is it completely reliable and functional now?
Thanks in advance.
Thanks in advance.
Posted Fri 10 Nov 23 @ 11:34 pm
Works fine. I would say go for it.
Posted Sat 11 Nov 23 @ 1:03 am
Hello friends! I just got the Pioneer FLX 10 and controller VU Meters are just not correct. As you can see in the video VDJ meters are not cliping, but FLX 10 meters stays in red zone. Master meters also looks not fine. Using latest VDJ version. Tell me please that the meters shouldn't act like that.
YOUTUBE VIDEO:
https://m.youtube.com/watch?v=fvkx0UjxcXo
YOUTUBE VIDEO:
Posted Wed 22 Nov 23 @ 8:02 pm
i can confirm, the meters aren't correct at all
also, after a while playing my stems+fx start to act wierd, not doing what it is supposed to do :(
Posted Thu 23 Nov 23 @ 7:19 am
About VU Meters...
Long story : Read this topic from Page 8 .. https://www.virtualdj.com/forums/251695/VirtualDJ_Technical_Support/Pioneer_DDJ-FLX10_Virtual_DJ_Support_.html?page=8
Short one : Map the VU METER key as .. get_level
Best solution : set zerodB setting in VirtualDJ to -6 (or lower)
Posted Thu 23 Nov 23 @ 7:33 am
djdad wrote :
About VU Meters...
Can confirm. Have mine at -9db and they work just fine.
However, the default is 0db and I don't think this should be the default.
Posted Thu 23 Nov 23 @ 7:42 am
Hi! Finally I have the flx10 and today I tested it.
I have been able to see that you have to lower the gain of each channel a lot so that it does not distort the sound. Master on 0 but if channels have mid position gain, music distort.
When I add new track to a channel the gain reset to mid. How I can disable auto reset gain when open new track and keep gain of the flx10?
Posted Tue 13 Feb 24 @ 11:44 pm
You should lower the zerodb setting inside VirtualDJ instead of keeping all gain controls to let's say 11 o clock position.
So, open settings, search for zerodb and set it at -6 or at -9 db
Posted Tue 13 Feb 24 @ 11:50 pm
Any have a list of all manual fixes with virtual dj and flx10?
Posted Wed 14 Feb 24 @ 6:20 pm
Just got the Flx10 and it's awesome, great job team.
Just one thing, is it possible to set the filter knob to vocal (stems) on starting VDJ with the unit as it seems to be defaulting to just filter when started up. Thanks!
Posted Fri 26 Jul 24 @ 9:53 am
No, no, no !
The default settings for the DDJ-FLX10 are just perfect .
When you play with central decks (1 & 2), you automatically have the stems on outer decks (3&4) with stems.
The middle of deck 3 is the voice stem of deck 1.
It's just perfect like that.
Posted Fri 26 Jul 24 @ 10:03 am
I meant per deck rather than globally.
Posted Fri 26 Jul 24 @ 10:06 am
In this case, it would be better to do it with a personal mapping and not by default, because most users will want to find the filter function on the filter button :)
Posted Fri 26 Jul 24 @ 10:14 am
And don't forget that on the DDJ-FLX10, you also have a button for direct access to the vocal stem
Posted Fri 26 Jul 24 @ 10:16 am
That's what I meant, not a change to the default mapping
Button is either on or off where the filter knob goes between full instrumental and full vocal.
Posted Fri 26 Jul 24 @ 10:29 am
It would be an ONINIT thing I guess. Where's Locodog? :-)
Try
Try
ONINIT filter_selectcolorfx "vocals"
Posted Fri 26 Jul 24 @ 10:50 am
There are 6 keys in the Mapping named as COLOR_FX_* , Find the one yo want to replace with the Vocals and simply edit the action and replace the Color FX name of the script.
Then you will have that button to select the Vocals Color FX
but i am not sure if it will still default to FILTER after a power-cycle. If so, it's a firmware limitation.
Actually, just checked Mapping files and there are no MIDI Out controls for those buttons (no software leds), so the device is doing its own things here.
Posted Fri 26 Jul 24 @ 11:11 am
What about this one?
![](/img/410766/45669/Screenshot 2024-07-26 131244.png)
Posted Fri 26 Jul 24 @ 12:09 pm
That's the button that selects filter, so if you want that to select vocals instead, just change 'filter' to 'vocals'.
Posted Fri 26 Jul 24 @ 12:15 pm
