Topic: Build 7388 - Countdown script
Version 7388 also mentions "Countdown script", but it doesn't work at all for me. I entered various parameters there according to the instructions, but nothing. Can someone advise me and us how to set it up. Thank you very much!
Posted Wed 14 Dec 22 @ 1:55 am
I tried both options (DENNYO BEATS and Locodog) but neither of them work. Respectively, the time appears, but I cannot change it in any way, even if I enter it in the parameters. Couldn't the developers do something like SBDJ countdown to the 32 bit version? It would probably be much easier. Like many, I also used this plugin a lot, but with the arrival of the 64bit version, it could no longer be used.
I'll create a video about how you can use it eventually
But for now you can use the previous script:
WAUU!!! Absolutely awesome job! Thank you very much!!! I probably wouldn't have been able to create this myself!
I would also be interested in how another time could be added there, not just midnight. I don't see any possibility to adjust the hours in that TXT.
86400 is the amount of seconds in 24 hours, that's where/how you set the time.
Thank You very much Locodog!
