Hi there. I'm using a Numark Platinum FX with a Behringer BH770 and VDJ b7183 build. When i turn the volume for the headset all the way up i don't get the normal output in them. The headphones are very silent at max volume.
This has been happening for the past two weeks, not since the beginning. I did not change any settings in the software. When testing with Serato Lite with the same headset, i get the full volume output, meaning they play very loud.
I tested several other versions of VDJ and had the same issue everywhere. Any thoughts ? your feedback is much appreciated. Thank you !
Posted Sun 27 Nov 22 @ 3:25 pm
Apparently resetting the software solved the issue. I still don't know what the problem was though.
Posted Sun 27 Nov 22 @ 3:44 pm
Virtual DJ Settings "headphonesGain" ?
Posted Sun 27 Nov 22 @ 3:52 pm
Hi there. I am struggling with my headphone volume when mixing. The sound comes out on both speakers even if the headphone cue button is selected. I use the dixon midi controller (welljoint cd1310). And for headphones, I use the DXN Pro Y80 headphones with an impedance of 32ohms. Please help.
Posted Mon 30 Dec 24 @ 5:26 pm
