Topic: Spotify and Virtual DJ
Playing Spotify on my DJ computer is just fine. But once I open Virtual DJ , the Spotify sound stops. Is there a way around this issue?
I’m using my RMX controller as the sound output.
Posted Fri 04 Nov 22 @ 8:04 pm
turn off exclusive audio access
if you have it on so you can adjust latency of your controller that will go back to default
Go in the Virtual DJ Audio Setup and toggle the Output from Asio to WASAPI. The Audio Latency i slower than. But you can use parallel other Aplications with your Soundcard.
Just curios, AFAIK Spotify stopped supporting VDJ some time ago. How are you still using it on VDJ?
The OP is using it from the web browser, not VDJ.
