Forum: VirtualDJ Plugins
Topic: Syphon - Page: 1
Who can we get a new syphon plugin from??
This is long over due.........
Posted Sat 22 Oct 22 @ 3:54 pm
Anyone??
Although it seems there has been some work on making Syphon compatible with Metal, the latest public release is still from 2019 before that work started.
You can give scott's beta plugin a try
https://forum.sbdj.co.uk/viewforum.php?f=21
I'm not sure if it uses the unreleased code from Syphon or if it converts from Metal to OpenGL though, so performance may not be optimal.
From our side, we will probably have a mac version of the NDI plugin, I don't know if that would work with the other software you want to use?
Yes please, the NDI will work with Mix Emergency 🤙🏾
Any headway made on this??
Yes, but will require some updates within VirtualDJ too, so has to wait for next VirtualDJ update
Sounds awesome and I can not to try it out!!
Thank you 🤙🏾
NDI-Receive is now available through Extensions for Apple Silicon macs and should work with current VDJ.
NDI-Send will be added later (requires a VDJ update)
Ok I’ll have to wait for the Send to get finished because I want to send VDJ into Mix Emergency.
Can’t wait 🤙🏾
Now available, should work with VirtualDJ EA build 7333
Anyway to separate this so I can use it on each deck??
Just start the plugin on each deck i think?
I’ll try it again but I swear it would only pick up 1 or the other (which ever I started first)
Ah yes, the name of the source is always "VirtualDJ", so probably can't tell them apart.
Yup that’s what it’s doing.
Anyway to rename the plug-in? Like SENDER2 for example 🤷🏾‍♂️
No, it's not based on the plugin name, but I'll update soon so that when used on deck it adds the deck number to the NDI name to make it recognizable.
Awesome and 🙏🏾
Update should now be available
Still doesn’t show up at 2 different Sends.
Only 1 instance of VDJ shows up in Mix Emergency.
The name is the same for both decks
74%
