klausmogensen wrote :
What are you missing in the VDJ stems fx implementation?
Just that it's the same as the 4 pre-defined ones in Serato?
In VDJ the Stems FX are done a bit differently
- but the idea is the same, except that it's less pre-defined, so you can stil lchange the fx's in the regular way:
user22874213 wrote :
+1 for the pad page effects of Serato Stems. That's definitely a feature which would be great to have in VDJ.
Its comes down to simplification. Like in this picture the part that's missing is the bass stem which should actually be there, Im wondering why it's not. Does the melody stem also include bass? why?
But Im sure a pad page can be made like seratos with the right scripting. I actually asked for a script in the script school section locodog has. It just makes sense.
Posted Wed 05 Oct 22 @ 6:35 pm
djjohnnyrox wrote :
I like the button placement on the pads below each stem and how you can choose the echo out for each stem
the SOUND INSURGENT wrote :
We have been able to do that for quite some time now.
djjohnnyrox wrote :
I do like their echo out feature.
But its horrible, the worst among its peers. Its amazing how the devs don't realize that. It needs a rework.
Posted Wed 05 Oct 22 @ 6:38 pm
We have it set the same way lol!!
Posted Wed 05 Oct 22 @ 8:44 pm
Come on, you’ve been around long enough to know that the “bass” can be swapped out with that echo button with a few minor changes lol!
Posted Wed 05 Oct 22 @ 8:49 pm
I been around long enough for everyone to know I'm just not understanding scripting...like dumb dumb with scripting.
Plus those stem echo outs need to be part of the script also. keeping the function to 1 pad press and that's it.
Posted Wed 05 Oct 22 @ 10:48 pm
There is no truer statement
https://youtu.be/2A5D9GIDb4k
if a mod could embed this, please???
Posted Wed 05 Oct 22 @ 11:30 pm
here is a comparison video
https://www.youtube.com/watch?v=09lOxReEQs8
you decide
you decide
Posted Thu 06 Oct 22 @ 1:19 am
Where do you enable the "Stems FX"? I can't seem to find this tab, I only have a single Stems FX button.
Posted Thu 06 Oct 22 @ 6:17 am
you need to install the padpage extension Stems FX (created by Rune)
https://virtualdj.com/forums/240330/addons/Stems_FX.html?page=1
https://virtualdj.com/plugins/?addonid=81310
may also also interested in Stems Remix
https://virtualdj.com/forums/240393/addons/Stems_Remix.html?page=1
https://virtualdj.com/plugins/?addonid=81316
Posted Thu 06 Oct 22 @ 6:34 am
Here's the original video, rather than a smaller screen grabbed copy uploaded by someone else:
https://www.youtube.com/watch?v=_4Q04V8HFJA
Posted Thu 06 Oct 22 @ 4:34 pm
Testing both myself on the same equipment with the same track, and I use nothing but VDJ for my gigs I can say there is a clear difference in sound......
I agree, I have teste equally; same track on both, SDJ sounds more clear. Just like U I only use VDJ for gigs; the rest just to have fun and play around; since I like almost all Dj software, but my choice is VDJ.
Posted Thu 06 Oct 22 @ 6:24 pm
Only wanted to focus on that part of the video because of what he saying.
Posted Fri 07 Oct 22 @ 8:23 am
Maybe not the right place to ask but do you know if on VDJ you can assign default switchable effects to different stems as per this possible rane one MK2 teaser LCD read out?
https://www.reddit.com/r/DJs/comments/xyw1fq/rane_shows_off_new_led_screens_and_pads_on_a/
Posted Thu 13 Oct 22 @ 8:24 pm
Yes exciting to see what hardware will come out, which adds more controls for stems. And hope that it does not take Serato another few years to add knobs to control stems, since I would love controllers to with sufficient controls for 4 deck EQ and Stems.
In reality it is not that big of a deal to add a touch-pad (launchpad) and some additional knobs (midi fighter twister) to have more then enough controls to do everything one can imagine with the amazingly powerful and flexible VDJ scripting. (though still cooler to have everything on one deck.)
______
I added the leaked photos of the new Rane, showing off the incorporated Serato stems:
______
Posted Thu 13 Oct 22 @ 9:07 pm
I used the knowledge I gained from the Stems FX plugin, to create my own Pad mode, which incorporates an Echo Out without any Bleed of the Stems. So it resembles more the implementation used in Serato. Have a try if you like :)
<?xml version="1.0" encoding="UTF-8"?>
<page name="Serato Stems">
<pad1 color="color 'magenta'" name="Vocals">var "VocalMuted" ? mute_stem 'Vocal' & set_var 'VocalMuted' 0 : mute_stem 'Vocal' & set_var 'VocalMuted' 1</pad1>
<pad2 color="color 'red'" name="Melody">var "MelodyMuted" ? mute_stem 'Melody' & set_var 'MelodyMuted' 0 : mute_stem 'Melody' & set_var 'MelodyMuted' 1</pad2>
<pad3 color="color 'blue'" name="Rhythm">var "RhythmMuted" ? mute_stem 'Rhythm' & set_var 'RhythmMuted' 0 : mute_stem 'Rhythm' & set_var 'RhythmMuted' 1</pad3>
<pad6 name="Echo Out" color="color 'red'">var "MelodyMuted" ? mute_stem 'Instru' & mute_stem 'HiHat' & mute_stem 'Bass' & set_var 'MelodyMuted' 0 : effect_stems Melody on & effect_active 1 'echo' on & wait 0.75bt & mute_stem 'Instru' & mute_stem 'HiHat' & mute_stem 'Bass' & wait 3bt & effect_active 1 off & effect_stems Melody off & set_var 'MelodyMuted' 1</pad6>
<pad8 name="Echo Out" color="color 'cyan'">var "AccaMuted" ? mute_stem 'Melody' & mute_stem 'Rhythm' & set_var 'AccaMuted' 0 : effect_stems Melody on & effect_stems Rhythm on & effect_active 1 'echo' on & wait 0.75bt & mute_stem 'Melody' & mute_stem 'Rhythm' & wait 3bt & effect_active 1 off & effect_stems Melody off & effect_stems Rhythm off & set_var 'AccaMuted' 1</pad8>
<pad5 name="Echo Out" color="color 'magenta'">var "VocalMuted" ? mute_stem 'Vocal' & set_var 'VocalMuted' 0 : effect_stems Vocal on & effect_active 1 'echo' on & wait 0.75bt & mute_stem 'Vocal' & wait 3bt & effect_active 1 off & effect_stems Vocal off & set_var 'VocalMuted' 1</pad5>
<pad7 name="Echo Out" color="color 'blue'">var "RhythmMuted" ? mute_stem 'Rhythm' & set_var 'RhythmMuted' 0 : effect_stems Rhythm on & effect_active 1 'echo' on & wait 0.75bt & mute_stem 'Rhythm' & wait 3bt & effect_active 1 off & effect_stems Rhythm off & set_var 'RhythmMuted' 1</pad7>
<pad4 name="Mel&Rhyt" color="color 'cyan'">var "AccaMuted" ? mute_stem 'Melody' & mute_stem 'Rhythm' & set_var 'AccaMuted' 0 : mute_stem 'Melody' & mute_stem 'Rhythm' & set_var 'AccaMuted' 1</pad4>
</page>
</page>
Posted Fri 14 Oct 22 @ 10:48 am
Excellent, thank you. This should be listed as an optional pad extension imo.
Would be great to add 2 further effects such as brake to fit a 16 pad layout.
Posted Fri 14 Oct 22 @ 12:18 pm
I tend to agree with you
Simplicity - That is what Serato is all about
Could they make 50 just as good stems Stems FX pads as the 4 that was included?
Yes, certainly - the building blocks are there
But you would then need to figure out which ones you liked, maybe tweak them a bit (length, filter, strength reverb and so on), and put them into something that is easily accessible, including from pads on a controller/mixer
So they decide not to give the users all the features in all combinations
Right now they give you exactly 4 Stems FXs, that is pre-defined, pre-mapped, and that you can't mess up when using. There is just an on/off button for each one
That is generally the Serato way:
Limited features, but pretty good ones, and useable with next to no learning curve
The VDJ way is kind of the opposite - you get everything available to you with hardly any limitations, and you can pick and choose and configure and map and script. And if something obvious is missing the first time, you get it in the next release in a couple of weeks
l personally really like the VDJ way, because I'm a tech guy :)
But I can understand why some prefer the simplified Serato way
Anyway...
I may have created the script/padpage you are asking for:
Posted Fri 14 Oct 22 @ 12:34 pm
