When I
clink on song in folder to place in deck it will not work.
Posted Tue 19 Jul 22 @ 8:13 pm
Need further info if possible.
Are you trying to drag a file from within the VirtualDJ Browser, or from Explorer/Desktop ?
What message do you get on the Deck when you drop ? Some specific error ?
If you think the dropping is not working, then perhaps try with the default VDJ skin - if not already using this.
Posted Wed 20 Jul 22 @ 4:51 am
