Hi how do i get DVS working on my DDJ-RX? I've currrently changed my input to line on the hardware which makes the timecode move but no music, only timecode noise.
Is there a setting that needs to be changed in the units safe mode possibly?
I have read this: https://virtualdj.com/manuals/hardware/pioneer/ddjrx/advanced.html
There is no pad page called DDJRX DVS in the pads drop down. Yes the gear is plugged in and vdj inputs are set to timecode exactly as shown in the last picture in the link.
Thanks for any help :)
Posted Thu 16 Jun 22 @ 8:57 pm
Look into VirtualDJ Settings->OPTIONS->CONTROLLER sub-cat. The setting should be at the top
Posted Thu 16 Jun 22 @ 11:29 pm
What is the name of the setting?
In the subcat controllers I do not see anything relatable to the topic, unless it's 'disableBuiltInDefinitions'?
Posted Fri 17 Jun 22 @ 11:20 am
Sorry, my bad. The DVS Setting should indeed be in the DDJRX DVS Pads page, as per the manual.
You dont have such a Page available in the list ?
Note that the DDJ-RX needs to be connected to get this page.
Which Build of VirtualDJ are you using ? Please download and install the latest official from https://virtualdj.com/download/
Posted Fri 17 Jun 22 @ 5:29 pm
